Trasparent background - Cloud Render
admaiora
Mentor Mentor
Message 1 of 10
admaiora
Am i missing something?
I want a trasparent background...
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
Replies (9)
Message 2 of 10
admaiora
nothing?
Admaiora
Message 3 of 10
TrippyLighting
Not only do you have to enable that option as shown in your screencast, but you'll also have to enable that option when downloading the image. Only PNG and TIFF file formats define transparency for pixels.
Message 4 of 10
admaiora
Hi, has you can clearly see in the video I did it both.
Admaiora
Message 5 of 10
TrippyLighting
Darned, you are right!
@paul.clauss here's a bug.
So here is one workaround.
  • Disable the ground plane in the screen setup before rendering.
  • Also set the background to "solid color"
Then your objects will be rendered in front of a single colored backplane.
Once rendered, you can use any image editor - I use Pixelmator below - to change that color to be transparent. YMMV.
Message 6 of 10
TrippyLighting
Actually, if you download the image in TIFF format it works properly
Message 7 of 10
paul.clauss
Hi @TrippyLighting @admaiora
Thanks for posting! This one is a known issue, logged internally as FUS-39686. We came across it in this thread
I've found that sometimes PNG format or TIFF will work for the transparent background, but which one actually gives the transparent background seems to vary by file. I also think @TrippyLighting has a pretty good workaround here.
I'm happy to keep you posted with any progress from the development team on this!
Paul Clauss
Product Support Specialist
Message 8 of 10
admaiora
Thank you @paul.clauss!
Admaiora
Message 9 of 10
TrippyLighting
You're welcome!
Message 10 of 10
admaiora
Thank you @TrippyLighting too of course!Smiley Very Happy
Admaiora
