Fiber Optic Modelling
I am pretty new to Fusion 360, coming from a background in SketchUp.
I am hoping to switch over to using Fusion 360 for my design work. I have a client who recently requested benches which would require fiber optics embedded in concrete for a light display.
Is it possible to model fiber optic lines in Fusion 360? If so, could someone offer advice or point me to a tutorial on how to do so?
Thanks so much!
Chris
TheCADWhisperer
Go through the Getting Started Tutorials and then after you have completed them - investigate Pipe and/or Sweep commands.
You might also investigate 3D Sketch intersections (advanced topic) if needed.
Once you have gone through the Tutorials - File>Export and then Attach here the .f3d file of your initial attempt.
