Transparency issues in render
tom_trotobas
tom_trotobas
I am trying to render a part, and some of it becomes transparent when rendering (although it is not supposed to). Previsualisation looks fine. It is not due to having transparent background option activated, i've checked. I tried different apparences too, and it's not resolving the issue, same for backgrounds and lighting
Thanks in advance
CGBenner
Welcome @tom_trotobas
I've moved your post here hoping to get more help on it.  Good luck!
Chris Benner
tom_trotobas
It appears to be linked to the presence of a sticker on the part. When it' s hidden, it's working fine again. I wouldn't say it's due to my sticker as it is on an other part and it works just fine
CGBenner
@jhackney1972 Do you have any advice in this area?
Chris Benner
atul.kumarJEBWD
HI @CGBenner , Tom has created a support case for this issue and I am following with it. I have requested file and will keep you in the loop as well. Thanks.
tom_trotobas
Just emailed it to you, hope you receive it this time around
CGBenner
@atul.kumarJEBWD @tom_trotobas Thank you both!  I hope you can get this resolved.  🙂
Chris Benner
