Transformer and motor winding coils
Filip_Kollar
Filip_Kollar
Hello everybody,
I've been trying for some time creating a motor winding or transformer coil, but I was not able to make it as I wanted.
For example, I know how to create a coil around a nice torus but transformers usually don't use this shape but rather rectangular core profile around which it is harder to create winding.
https://youtu.be/r6TCSsdD3hA
https://www.globalspec.com/ImageRepository/LearnMore/201211/tra_toroidal563e2a83a7d44f81a9a3627b63a8...
A motor winding example which I would like to know how to recreate
I have this transformer which I want to model inside a Fusion.
This is the result.
I would appreciate any interesting ideas on this topic Smiley Wink
Thank you in advance!
Replies (8)
KKizildemir
Hi @Filip_Kollar
Are you looking for just a visual solution? If yes, please draw a rectangular profile around the section of your transformer's core. Then make a solid body by sweeping this profile.
I've modelled a part for you. Please find it attached.
Signature
website
emailskypelinkedinyoutubeemail
Filip_Kollar
Sure, this is one good solution to make it just look like a transformer, but any ideas on how to make it real? Also, the spacing between windings is too big or they will start to overlap with each other.
KKizildemir
@Filip_Kollar
Adding new, longer path of sweep on the plane which has a small angle with the previous sweep feature's plane could make this OK. Please see the doc attached.
Signature
website
Filip_Kollar
Ok, that good enough I think 🙂 Thank you for help, also one tip from me, as I saw in your history, you can just use pipe command instead of making construction plane, sketching pipe shape... it is much faster in this case I think.
KKizildemir
Oh, Thanks for your feedback!
Have a nice day!
Signature
website
HughesTooling
@Filip_Kollar  Here's an example using a similar method to the youtube link in your first post. Not sure you'll be able to use it to create a fine pitch coil but might be useful for you. The idea of trimming the patch coil could also be used for the rectangular coils on the motor in your first post as well. I set up a few sketches before the screencast, file's attached.
Mark
Mark Hughes
Owner, Hughes Tooling
Filip_Kollar
That intercept was a very interesting way of creating that and yes, I think that this can be used to create real coil windings, but the main problem, in this case, is performance, in my case I used 360° x 200 and fusion was in "not responding" state for a few minutes even on my i7 8086k with GTX 1060 😕
Thank you very much and have a nice day Smiley Happy
TrippyLighting
@Filip_Kollar wrote:
...Also, the spacing between windings is too big or they will start to overlap with each other ...
Correct! If you look at a real toroidal transformer you'll see that often the dissection is not perfectly rectangular but thicker in the middle.
