Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Trace forcing full retract
3 REPLIES 3
ea425019
211 Views, 3 Replies
Hi, take a look at this file's CAM tab.  I was setting retracts of about 6mm but was getting 10x that much, so the runtime was really long.  Any ideas?
3 REPLIES 3
jhackney1972
in reply to: ea425019
Take a look at the attached file and see if it suits you better.  I worked your heights off of the stock top which is better for the control you desire.
John Hackney, Retired
TrippyLighting
Please post CAM questions in the Manufacturing section of the Forum.
ea425019
in reply to: jhackney1972
Trippy L, got it...
Hackney, thanks.  That solved it, retract height was specifically causing it in my model.  I suppose it's a bug, but for now can run with this.
Thanks!
