Trace forcing full retract
3 REPLIES 3
ea425019
234 Views, 3 Replies
Hi, take a look at this file's CAM tab.  I was setting retracts of about 6mm but was getting 10x that much, so the runtime was really long.  Any ideas?
3 REPLIES 3
jhackney1972
in reply to: ea425019
Take a look at the attached file and see if it suits you better.  I worked your heights off of the stock top which is better for the control you desire.
John Hackney, Retired
ea425019
in reply to: jhackney1972
Trippy L, got it...
Hackney, thanks.  That solved it, retract height was specifically causing it in my model.  I suppose it's a bug, but for now can run with this.
Thanks!
TrippyLighting
Please post CAM questions in the Manufacturing section of the Forum.
