Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Toolbox Assembly Small Issues
2 REPLIES 2
275 Views, 2 Replies
Hi everyone,
I've finished a custom toolbox assembly for my job, and there are a few issues that I can't work out how to fix.
1.) There's what I think are 'contour lines' on the toolbox, in places that I have no idea why there would be contour lines. I can't delete them, and when I try to combine, no part of my toolbox is selectable as 'target body'.
2.) I also wanted to see if I could get some help squaring my design. I attached a picture from the top and you can see it's a bit off.
3.) I was wondering if there is a way to organize my browser tree into folders, or at least moving something from far down on the tree to somewhere else in the tree. I don't think so, but if anyone has any ideas, that would be great.
Thank you!
Labels (5)
2 REPLIES 2
fusiondesigner
Could it be because the components are external designs that have been inserted into this design, and are therefore read-only by default?
BHOOM
I understood that you don't wanna see contour lines right?
1.Just press CTRL+4 it hides the contour lines.
For organising just hold and drag the body to a desired component in that way it looks nice and clean.
2. For selecting the components in selection filters make sure you've checked everything.
