Tool path error
Tool path error
Tool path error
My tool paths are above and below selected 3/4 stock.
New at this and could use some help.
THANKS
Bud_Schroeder_ADESK
Hi Ken,
Thanks for posting to the forum. I'm going to move your post to the Fusion forum so that the right team can help out with your tool path question.
Hope this helps.
Bud Schroeder
AutoCAD Customer Council Beta Programs
Autodesk Inc.
Join the AutoCAD Customer Council Beta Program.
Thank you
Ken
Please note when replying via email any signature used by your email client will be added to your post as with any other email.
Please be aware that this is a public forum posting serial numbers or personal information is not advised
Edited by
Discussion_Admin
HughesTooling
On the Heights tab for the Top Height select model top and for Bottom Height select Model Bottom. You could select Stock Top and Stock bottom as long as you have them set coretly in the setup.
Mark
Mark Hughes
Owner, Hughes Tooling
Did no change the proplem
HughesTooling
Can you export the file as an f3d and attach to this thread. From the File Menu select Export.
Thanks Mark
Mark Hughes
