Title block - data missing
DanMartlev
DanMartlev
When opening my drawings, data in title block and dimensions is hidden.
Zoming out, I can see there is some thing, but zoming in again - it's hidden.
When I move my mouse around/over the title block - it shows the data.
Any settings which causing this issue?
ClintBrown3D
Hi @DanMartlev
I'm sorry to hear that you are having trouble. This sounds like a potential graphics issue.
Could you share a screenshot of the problem with us? Also, please can you share your graphics diagnostic with us?
Clint Brown
Senior Product Manager - Autodesk Fusion
Book some time on my calendar
The Ultimate Guide to Drawing Automation
DanMartlev
Hi Clint
Strange – I closed the drawing, and when reopening, it’s all there.
I have experienced this before… and now, I can’t recreate the issue with this exact drawing.
But the below is from one of my templates – which right now did the same!
[cid:image004.png@01D93179.827FAEB0]
[cid:image008.png@01D93179.827FAEB0]
The below shows another issue – my logo should be in blue, and I see it (short flash) when I open my file, and the it turns Black!
[cid:image001.png@01D93177.727F60C0]
[cid:image002.png@01D93177.8A00FC90]
[GPU Information]
GPU Device: NVIDIA T500
GPU RAM: 4096 MB
GPU Driver API: DirectX 11.0
GPU Driver Version: 517.13
GPU Driver Date: 09/01/2022
[Graphics Effects Settings]
Anti Aliasing: On
Ambient Occlusion: On
Object Shadow: Off
Ground Shadow: Off
Ground Reflection: Off
Selection Display Style: Normal
Transparency Effect: Better Performance
[Limit effects to optimize performance]
Off
ClintBrown3D
Hi @DanMartlev
None of those images attached to your post, unfortunately.
But I'm glad that you are sorted. There are 2 things you can try the next time you see this issue.
1: Clear your cache
2: Look at your graphics setup. Several months back, Microsoft changed the way that graphics cards are managed, meaning that tools like the NVIDIA control panel no longer control which apps are optimised for your graphics card! I write a handy guide to help you get set up here: https://clintbrown.co.uk/2022/07/27/troubleshooting-dual-graphics-cards-on-windows/
Clint Brown
DanMartlev
It still happens - but randomly. I can't see/find - if it's a special action I do, besides just open my drawings.
