Timeline Grouping Improvements
- Mute
- Permalink
- Report
I would like to see some improvement of the timeline grouping feature. The grouping feature is helpful for keeping an organized design history, but it lacks features to make it more efficient.
As far as I know, the only ways to add a feature to a group is to roll the timeline into the middle of group and create a new feature. You can rearrange features within a group. Alternatively, you can delete the group, select the additional features desired, and regroup (this is too time consuming). To remove a feature, I believe you need to delete the group and regroup as well.
1. Drag-and-Drop into group or out of group.
You should be able to drag this fillet feature into the middle of the group or to the end, as the last feature in the group. You should also be able to drag a feature out of a group.
2. Select and Add to Group
You should be able to select all these features and roll them into the selected group. I'm not sure if it makes sense to support selecting features prior to the selected group.
3. Add to End of Group
Right now, you can only add to an existing group if you roll the timeline cursor into the middle of a group. I should be able to add a fillet feature to the end of this group.
All of these features would require some sort of prompt or GUI-indication to determine user intent. Ex: Add to end of group or keep feature separate, remove from group or move to end of group, etc.
If there is any way to accomplish actions like this or other handy workarounds, let me know!
