Is there a way to modify a group in timeline?
razoredgekniveS
Message 1 of 10
razoredgekniveS
I searched but can't find anything recent and the option to 'delete group and expand contents' is no longer an option.
I want to add the last sketch to the group right before it
Replies (9)
Message 2 of 10
jeff_strater
I don't see a group in your design.  As far as I know Delete and Expand is still functioning properly for timeline groups.  Would be interested in seeing such a case if you have one.  Thanks.
Jeff Strater
Engineering Director
Message 3 of 10
razoredgekniveS
Interesting that it didn't show in that one, try this one
Message 4 of 10
mango.freund
hi @razoredgekniveS take that. greetings mango
Message 5 of 10
razoredgekniveS
Thank you, but how do you add an item to a group once it's already formed?
Message 6 of 10
mango.freund
@razoredgekniveS click on the plus sign and he'll open it
Just start your new campaign. it is not necessary to pack everything into one group. remember that each group can have a name that you assign to it.
Message 7 of 10
razoredgekniveS
Thank you but I would still like to know how to undo a group once it is made, there definitely should be a way to do it
Message 8 of 10
jhackney1972
Attached is a Screencast of the process you are looking for.  Probably why you did not see it earlier is because you must chose to "Delete" the group, to the see the options, to add to it.
John Hackney, Retired
Message 9 of 10
jeff_strater
it seems to work for me:
In fact, the first model that you shared looks like you had done exactly that.
Unfortunately, there is no great way to edit a group at the end.  What is needed is an edit mode.  However... if you are OK not inserting at the end, just roll  back into the group and add features - they will just get absorbed into the group. (a group is really just a start feature + end feature reference).  I sometimes will put a dummy feature there (a workplane I never consume) just to let me do that.  Yeah, it's ugly...
Jeff Strater
Message 10 of 10
razoredgekniveS
John you nailed it, thank you! For some reason I tried that but it didn't work the last time. Glad it is now!
