Threads on nut and bolt don't align. Can't understand why
paulo_peppe
paulo_peppe
Hi All! I am developing a small container for an AirTag to be 3d printed. Happens that I applied the same thread (m36x2) to the internal and external surface of models, but for some reason I can't figure out they are not aligned. I have done this before and both threads automatically aligned from beginning. Could anybody help me to figure this out? I have attached a section view and the model. Thank you a lot.
Link for the model:
https://a360.co/4bjW4SQ
g-andresen
Turn the cap a little
günther
MRWakefield
In my experience you're lucky if the internal and external threads on an assembly such as this line up without a bit of fiddling. I'm not sure how Fusion decides where to start the thread helix from but you can just rotate one of the components until the threads line up. In the below screenshot I created a joint between the two parts with a rotation of 64°.
Hope this helps.
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
paulo_peppe
Thank you guys! So I understand that as long as I use same parameters I am good to go, even though it might look unaligned on screen, right?
As for the "create a joint", is it a better solution than rotating it manually?
Thank you again!
MRWakefield
Thank you again!
Whenever you have an assembly it's always best practice to connect the components to each other with joints. Using joints means that you have a more robust and predictable model. As an example: in your model you're able to drag the cap around in free space, there's no relationship between the two components. If the cap gets dragged away from its intended position you might not notice and could cause some head-scratching down the line when things don't look quite right and you don't know why. Joints tie everything together and enable other functionality in Fusion such as motion links.
Marcus Wakefield
g-andresen
The point here is to make it clear that it is only a matter of a different starting position of the threads.
The print result is not affected by manual rotating or a using a joint.
günther
