Thread drawing problem, or how to draw new lines on an existing piece
kevinmamaqi
kevinmamaqi
I have a section view of a threaded part, but it looks horrible. If I disable the thread feature from the 3D, then I don't know how to add a line to indicate that there's a threaded part. See the image attached.
How can I draw a line or how to include a normal thread view like in other software (inventor, for example)?
Freelance Industrial Designer - Contact me here
andrew.de.leon
Hi Kevin,
In the next major update we have added support for cosmetic threads, so in the drawing you will see the additional lines you are looking for. Like almost everything else in Fusion 360 Drawings, the representation of cosmetic threads will be compliant with ISO and ASME drafting standards.
Hope this helps, and sorry its not already available.
Andrew
15" Retina MacBook Pro (Late 2013), OS X El Capitan (10.11.3), in Sydney Australia
Andrew de Leon
Experience Designer - Fusion 360
MacBook Pro (16-inch, 2019), OSX 10.15.7, in Sydney, Australia
kevinmamaqi
When the next major update will take place?
andrew.de.leon
Hi Kevin,
If all goes to plan, you should see the update early April.
Andrew
Andrew de Leon
kevinmamaqi
Hello aj_deleon, is there a fixed date to solve this problem?
brianrepp
@kevinmamaqi it looks like this fix will end up being in our update in early May.  Thanks for the patience.
