Thread design
Thread design
Thread design
I'm trying to draw a thread with custom dimensions.  I have located the threading option in the menus, but I cannot alter any specifics of that particular thread. I can only pick the values from the pull down menu.  But if i wanted to make for example a M6.5 x 1.75 thread, I cannot do it.
Is there another way where I input my own values to create my own thread geometry?
I would draw a shape of a triangle then use a helix function, but I cannot figure out how to do it.
Is fusion able to do this?
Thank you,
kate.raskauskas
Hi @Anonymous,
You can use Create > Coil with a triangular profile to do this, or you can make a custom thread file with the dimensions you want.
Kate Raskauskas
Product Support Specialist
My Screencasts | Fusion 360 Webinars | Tip and Best Practices | Troubleshooting
SaeedHamza
What @kate.raskauskas said is the way to do it, and I would like to add something
You can use the coil as a path and then use a plane along path on it, so that you can sketch on it a custom thread section for example
Might help
Regards
Saeed
Saeed Hamza
