Thread change the dimension
hato54
Message 1 of 10
hato54
Have a pin dia 6 mm and like to thread this in the end, M6 and 8 mm long.
First I make the pin 6 mm in diameter, and then using the thread command (ISO 6 mm, lengt 8 mm).
Now the whole pin has change diameter to 5 mm!
 I like to have it as this:
Replies (9)
Message 2 of 10
HughesTooling
It actually changes it to 5.88, mid limit for the OD of a M6 thread, you can check here. What's annoying is it changes the whole length, this has been reported many times and is a limitation to the tool.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 3 of 10
TheCADWhisperer
This is what I would do.
Message 4 of 10
hato54
@HughesTooling
Strange, my changes to 5 mm?
Message 5 of 10
hato54
Thank's @TheCADWhisperer I did like this..
Message 6 of 10
JDMather
If I simply Edit the feature (without making any changes) the part fixes itself.
Can you create a Screencast Recording reproducing how you are getting into an incorrect state from scratch?
Message 7 of 10
HughesTooling
@hato54 wrote:
@HughesTooling
I see that now. When I open your file it's 5mm but if I edit the thread from the timeline it resizes to 5.88mm! Don't know how you've ended up with 5mm, I tried deleting the thread then adding back but that works correctly. @jeff_strater any idea how the thread in the timeline can be M6 but the models wrong?
Mark
Mark Hughes
Message 8 of 10
hato54
Ok @JDMather, here is the screencast:
Message 9 of 10
JDMather
What if you leave the Size on Auto?
I tried both ways and could not reliably reproduce the issue, but I think I was able to get the incorrect behavior in at least one of my attempts.
Message 10 of 10
hato54
@JDMather
If I use auto the diameter will be 5.884 mm (same as @HughesTooling)
