- Mute
- Permalink
- Report
Hi community!
I am trying to build and simulate a lead screw using Fusion 360. Having studied AutoDesk manuals and a bunch of youtube videos I seem to understand the way it should be done, however doing this in practice turns out to be not so straight forward.
I have built a rod and applied M5x0.8 thread to it. Then I have build a moving platform with a hole in it with the same M5x0.8 thread. Then, in order to prevent this platform from rotating with the rod I have made a cut in it's bottom and another component. And finally, to fix a rod to something I have created a box and attached one end of the rod using revolute joint. I have few contact sets: between rod and moving platform, between rod and a box. I am able to rotate the rod itself, it rotates inside a hole of the platform, however the platform doesn't move.
First thing I though when I've done this is the threads or hole diameters are different. However, having tried different options it appears they are correct. I have also made sure both threads are built with "modelled" option on.
Before I bang my head against this, could you please advise if what I'm trying to do is possible in Fusion 360. And if someone have done something similar, I would appreciate advises.
