Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Thermal Simulation of Heat Transfer between parallel plates in air
0 REPLIES 0
Message 1 of 1
jayendra_mandradiar2020
166 Views, 0 Replies
Observer
Observer
I have been trying to do a thermal simulation, and really struggling with the setup since this is my first time in thermal.
My scenario has 2 parallel plates inside a box made of steel. To simplify the setup, I have not included any mounting brackets, and I have kept the steel plates floating. One of the steel plates have a heater attached and is maintained at 100C. The other plate is smaller, and has a separation of about 100mm from the first plate. I want to estimate the temperature of the smaller plate. Below are the approx. dimensions and properties:
Outer steel box: 500x500x500 mm, and is made up of 3mm Mild Steel with Black Powder Coating.
Heater Plate: 300x300 mm, 2mm Mild Steel with Black Powder Coating. Temperature Maintained at 100 C, by heater.
Receiver Plate: 70x70 mm, 2mm Stainless Steel
Room Temperature Outside the Outer steel box: 25 C
Can someone guide me on how to setup the simulation for this scenario? I have set the component positions, but I do not now what type of thermal loads to give on each surface. Also should I manually add an AIR component? If yes, how do I do that?
Below are images of the setup. The box is closed on all sides. However I had attached an image without one side to show the plates inside.
0 REPLIES 0
