The Fuzzle B
The Fuzzle B
MichaelT_123
Advisor Advisor
The Fuzzle B
MichaelT_123
Hi Fellows,
As promised … here is the more challenging fuzzle – The Fuzzle_B.
It is a step evolution of the previous one:
https://forums.autodesk.com/t5/fusion-design-validate-document/the-fuzzle/td-p/12732984
Although the theme is very similar, the complexity of the problem is revolutionary higher. In the previous fuzzle post, I joked about the difficulty of entry into MIT and Yale UVs. I am not entirely sure which one would be more exigent; perhaps we are comparing here an in-the-shell-macadamia nut with the M&M button, respectively. Nevertheless, for the sake of sweetening the exercise, I will acknowledge the latter here.
The problem is as follows:
  • Devise formulas defining  i_th circle tangential to tangential circles inscribed on two vectors of angle and the vector itself.
  • The definition should include separate expressions for their radii and coordinate positions.
  • The form of the formulas should be as compact and mathematically esthetic as possible.
  • The circles to be solved are depicted in red in the following picture.
I will not rush to present the solution. I will also not reveal “how to solve” it … because it would hinder self-development and promote the launguorness of many … not to mention … feed AI Monster.
Notwithstanding … any fast response …. from the field Wizardswill be Very Welcome.
The result of the first ten radii - l=100, α=30°. (all digits but the last are significant)
0, 4.465819873852045
1, 1.4886066246173482
2, 0.49620220820578287
3, 0.1654007360685943
4, 0.05513357868953144
5, 0.018377859563177147
6, 0.006125953187725717
7, 0.0020419843959085726
8, 0.0006806614653028576
9, 0.00022688715510095256
Regards
MichaelT
MichaelT
MichaelT_123
Hi Fellows,
266 days have passed … and there is no answer to the Fuzzle_B.
I can only guess the reasons:
  • You were too beezee with your designs
  • The problem was too eezee to bother with
  • The issue was too deezzee
  • Fuzzle was too fuuzzee
  • … or perhaps there were other essential predicaments ???
Thus is the time to reveal The Solutionbefore it becomes too old.
The presentation is available in multiple formats, including PNG images and a PDF file, which serves as a metaphor for the F360 sketch.
Fuzzle_B_answer.png                      4K_mono        (0.3 ΜΒ)    https://a360.co/4lMQvBN
Fuzzle_B_skPDF_answer.png         XXL_mono       (1.4 ΜΒ)    https://a360.co/4454uwL
Fuzzle_B_skPDF_answer.pdf         PDF                   (141 KΒ)     https://a360.co/3Iiy9d5
Fuzzle_B_skPDF_answer.f3d         F3D                   ( 71 KΒ)      https://a360.co/40lQkon
To be viewed on 4K media devices (monitors, UHD TVs, projectors...) of reasonable performance. For the best experience, use stand-alone media applications (e.g., WMP, VLC) and display at the native resolution of 3840x2160 in full-screen mode. The '_arcd' files require anaglyph red/cyan glasses, while '_al' is for active shutter glasses 3D hardware (~30° viewing angle is recommended). Download the files over a network, where the cost of doing so is not a concern. The files are intended for private, non-commercial use only.
Regards
MichaelT
MichaelT
