the final render result came out with small object,and no materials are rendered
Screen Shot 2020-05-18 at 01.50.52.pngMOBIL_WOOYYYY_2020-May-17_05-24-10PM-000_CustomizedView5947656235_jpg.jpg
i tried to do a final render but the results made the object much smaller and the materials arent rendered. the left picture is the approximately the view and the size of the car i was going to render and it came out like the right picture. what should i do?
LeonardoBN
Hi @Anonymous. Is this an imported mesh (STL or OBJ)?
Did you use Local or Cloud Render?
You could share your F3D file and we can take a look.
Leonardo Brunelli do Nascimento
Chemical Engineer
No, i made this with surfaces. and no i didnt used in-canvas render. i used the 'render' one
zhaoning_yuan_dp
Community Visitor
Community Visitor
Hi @LeonardoBN
I've had a similar problem recently, but mine seems to be more severe. Please help me.
The model was built entirely in Fusion. Everything works fine with in-canvas rendering, but after entering the “render”: the local rendering has no light effects, and the online rendering outcome will be so small that it's almost invisible. The situation is as shown in the picture.
Same angle, same settings, weird different outcomes. This situation is very troubling to me.
Please please tell me what I can do or who I can ask. Thank you!!
Hope to hear from you soon.
With best regards,
Jony
TrippyLighting
Can you share a model with that behavior ?
