Cutlist drawing
Cutlist drawing
mika.takalo
Cutlist drawing
mika.takalo
Hey.
I have multiple sheetmetal parts in my assy. I want all those flat patterns on the one drawing, is it possible? It would be nice to export that one sheet to dxf, to get whole assy lasercut parts in a one file.
jhackney1972
I think the best you are going to do is create one drawing, for the assembly, and have one sheet, in that drawing, for each flat pattern.  This really does not help you with your job.
John Hackney, Retired
laughingcreek
to put multiple flat patterns on a single sheet, first create a drawing, either by going through the process with flat pattern, or the regular process (maybe you want an isometric view on the sheet also)
to add additional flat patterns to this sheet (admittedly this isn't intuitive-)
right click the flat pattern and create new drawing
under destination, pull down the menu for drawing and select the drawing from above (mine in the picture is literally named "untitled")
do the same with sheets and select the sheet-
wash, rinse, repeat.
here's 2 flat patterns on one sheet, you can put as many as you like-
jhackney1972
@laughingcreek
Kudos!  I did everything to find the solution EXCEPT for your last selection of the sheet.  Wonderful!
mika.takalo
Works perfectly. Many thanks!!!
