I wish Fusion 360 had the ability to combine counterbore with countersink when creating holes with the Hole tool. The use case I have in mind is a surface where you need a countersunk screw to be flush but you don’t have enough room to oversize the countersunk area. Every flathead screw has a rounded lip at the top of the head, so simply making the countersink the diameter of the head results in the top of the head being above the surface.
Does anyone have a quick workflow they use to accomplish this, possibly a script?
