the easiest way to design this?
Message 1 of 28
Hi guys,
I just designed this to repair my Hamilton Beach drink mixer.
While I loved the job, I think I didn't necessarily do it the best way so I was wondering on how you experts would go about it?
Anny suggestions for alternative ways to do it are welcome as we will always learn something new. i don't want to influence you so I will tell you how I did it afterwards.
curious to see your replies.
Best
Oliver
Replies (27)
Message 21 of 28
This is the one I printed. Its completely flat at the bottom where the wave touches the surface in order to make it printable without too much supporting structure.
Message 22 of 28
chrisplyler
Oooo I hadn't even thought of that!
How much angle CAN be self-supporting? Would something like this work?
This has been one of the most interesting threads to me....
Message 23 of 28
IMHO opinion, some of your designs are too thin et the edges.
The diameter of the disk is 22mm. I use minimum 2mm at the edges.
I now redesigned one following Chris' suggestion. I made it 24mm. I tried in the sculpt space but I didn't like the form as it was a bit more difficult to control the exact shape as it tended to "round" everything making it look overly organic.
This looks almost exactly like Chris' last design but is a lot thicker.
I think I will try to print it either without support structure or with minimal one. Will post one screenshot of a Cura model in a couple of minutes to illustrate.
Message 24 of 28
btw, how you insert the picture directly into the message?
Message 25 of 28
this is how a Cura 3d print slicing model looks with a 55 degree overhang support structure and superfine layer of 0.06mm.
the small disk will take 1.5 hr to print
Message 26 of 28
chrisplyler
Click here...
...then drag and drop the photo you've saved into the space. Then click the DONE button.
Message 27 of 28
Ok, great, Chris. guess that was obvious... sorry.Screen Shot 2018-03-23 at 20.12.28.png
Message 28 of 28
lichtzeichenanlage
Not at my desk... but... Photocamera for photos, Videocamera for videos
