How to smooth this object?
blisek666
blisek666
Hi.
I have a problem with smoothing a top part of this object ( It's 22.5 degree floor strip connector). Any ideas how i can smooth this top curved part? For the rest of this object i used loft and fillet but here i can't use fillet because i got error
TrippyLighting
What error did you get ?
Can you share you model ?
blisek666
http://a360.co/2IGsI4p
Here is a model. After this 22.5 degree i want to make a 90 degree.
Error: The fillets/chamfers could not be ordered to return a successful solution.
Try adjusting the size, removing some existing fillets/chamfers from the model, or manually reorder existing fillet/chamfer operations.
blisek666
Anyway i got this with revolve
