The configuration table does not display configurations correctly
marcus.toepke
Advisor Advisor
marcus.toepke
Hi all!
I've noticed that when you use configurations and eventually end up with a lot of them, they don't display correctly in the table.
When I scroll down, the last configuration appears briefly, but then gets pushed back down again! I have to start scrolling all over again to see the last configuration, and then it disappears again, as if pulled by a rubber band.
TrippyLighting
I have reposted in the EE Slack Channel to give it more visibility!
marcus.toepke
Thx!
But what is a EE Slack Channel?
TrippyLighting
Autodesk Expert Elite Slack channel. It allows Expert elites direct access to the development team.
I often post bugs there that I cannot post here on the forum, as all of my professional work in the manufacturing automation industry is under NDA.
BTW, the topic has received some attention there.
abhijeet.rajput
Hi Marcus,
Thanks for reporting.
We have already fixed the issue and we expect to get the fix out in May Release of the Fusion.
Abhijeet Rajput
Autodesk Fusion.
