Hi, I'm trying to recreate a logo and I need to transform the letters so they are barrel shaped.
I type the text, then I explode the text, then I unfix the text and this allows me to move the letters around as well as transform the shape of the letters with the exception of the letter "S". Some other letters are similar but the "S" is the worst.
I think it maybe a bug.
Grant.
This isn't really a solution to the "bug" you are experiencing, but have you tried to project the exploded text onto a cylinder face to achieve the barrel text shape? I don't have a lot of experience projecting text but I've got it to work a few times! Best of luck.
I hope it isn't too far down the list. 🙂
For some guys, it is crucial to be able to do simple line text for engraving. Especially those that need serial numbers, part numbers or very simple logo's. I can use any stick font and it would do okay I think. Others probably the same for serial and model numbers.
That is a pretty basic function and with the work arounds of importing an SVG file, it is no longer trivial. It took me 10 tries or so to get my text located and properly sized. Arggg. 😉
Solid Works has trouble with that too though.
Hello GPTech2444,
Just wanted to add some of my experience in working with logos/decals inside of Fusion 360,but working with a .svg is the best way to project letters; and then use CAM for Fusion 360 for engraving on a part. Here's a YouTube Video I put together a while back working with the project command and the trace operation inside of Fusion 360. Hope this helps in some fashion.
https://www.youtube.com/watch?v=G3Xt1Es_dg8&list=PLmA_xUT-8UlJjXkVwdduZ3PCgJMPEGRbU
Best,
Thanks for the video. It was a big help and how I was able to get as far along as I did. The SVG was made in Turbocad, so maybe some conflict there. It was saved in inches and imported the same way, but I had to scale it to .03 of it's imported size.
Once I did get it correctly placed on the sketch, I could setup machine tool pathing for the engraving. Okay there. Next I might want to render the part for my website. Well, that text will not render because it isn't actually into the part. I have to add different text and extrude like the video shows.
I am used to just exploding line text in Turbocad, importing into sheetcam and engraving at specific depth. Now granted TC will not render such text properly either, but I can get it to show up on the surface of a rendered part as lines.
I understand I am asking a lot to bridge both machining and graphics needs with the same data, but it works very well for most items that I would be using. I'm rooting for you guys. 🙂
