- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi, if somebody help me with this I will be very pleased.
1) These are two identical T-Spline Panel Squares.
2) Each side is 25cm
3)Also gap between them is 25cm
4)I want green edges to merge with purple ones. But while I'm doing this. I want purple edges to stay where ever they are. I only want green edges to move.
5)So I used "Merge Edge" option. (Later, I tried lots of modify options like "weld vertices".).
6) Side number one is 25cm. It is Good.
But side two is 29.167cm. NO! This is NOT what I wanted. I want side two to remain 25cm. Only side three and side four can change.
7) So somehow I need the ground purple square, then make "Merge Edge"
I do not want to make some handy work after the process like insert edge, move edge, etc...
Because sometimes it is become difficult to do it with your hand.
Also I do not want to make them component first.
Because when I do that. I can't edit the form again.
