Sine wave surface
Sine wave surface
Claus_J
Sine wave surface
Claus_J
With so many clever people here I'm hoping somebody can point me to a painless way to create a surface like the attached picture. Any hint is greatly appreciated.
Claus
TheCADWhisperer
Similar examples have been posted here in the past using Loft to Point and Pattern.
MRWakefield
Something like this?
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
Claus_J
Yes, exactly like that. How was it made?
Thanks!
MRWakefield
It's just a sinewave spline swept along another sinewave spline. It might not be super accurate but it's probably good enough for most cases. I wrote a very simple app to generate the points and then used the 'ImportCSVPoints' script to generate the splines. I've added a fabric appearance in the screenshot below to make it a bit easier to make out the shape. You'll find the app and the model attached. One day I might actually get around to converting the app into a Fusion Add-In!
Marcus Wakefield
laughingcreek
here is a different approach.  this may seem more convoluted at first, except making changes to the wave form only requires editing the first sketch.  the curvature is a little better to.
Claus_J
Thank you both. The sine curve along sine curve path is really simple. I would never have thought about the pattern solution but I love how flexible it is.
Thanks again for taking your time to help me, these solutions work for my project.
Claus
