t spine to solid
t spine to solid
grantpoadhindle
Message 1 of 8
t spine to solid
grantpoadhindle
hello ,
I have created a t spine pipe and modified it to fit the solid part..... I cant change the t spline to a solid with the convert command . it changes to a hollow solid .
I need it all to be solid to convert to a iges file for rapid prototyping.
any help much appreciated....Grant
Replies (7)
Message 2 of 8
Phil.E
If you want the pipe to have a wall thickness, use the command Modify > Thicken. You will have the choice of what thickness and edge treatment to use.
If you want the pipe to be a solid filled bar, you need to do more work on the surface body that is created when you finish the pipe.
  1. Convert the pipe
  2. Go to Patch workspace
  3. Use Patch command to cap the ends of the converted pipe
  4. Use Stitch to connect the end caps to the pipe
  5. The result should be a solid bar
Thanks!
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 3 of 8
grantpoadhindle
Big Thanks Phil !
got it .....eventually
Grant
Message 4 of 8
grantpoadhindle
Hi Phil ,
my patch workspace has disapeared...any ideas ?
Thanks Grant
Message 5 of 8
AndrewSears
Hi Grant,
The Patch workspace is currently not available in History Mode.  We are aware of the need to have the Patch Workspace within History Mode.
Please give a Kudo to Claas for putting this into the Idea Station.  "Patch needed in History Mode"
You can select the settings icon in the lower right corner to get out of History Mode.
Andy
Message 6 of 8
grantpoadhindle
Thanks Andy...sorted now....Grant
Message 7 of 8
grantpoadhindle
Hello again ,
after several weeks I am doing a similar project......could you advise the best way to join the 2 T spline sections......I am using match ..but seem to be gettin a bit of twist.. please see pdf .....
many thanks Grant
Message 8 of 8
deyop
I am not enthusiastic on Match for this connection.  It should work better but I just don't think you can expect good results.  I thought you might want to try converting the T-Spline and do a loft to join them.  Sharp corners to smooth is a challenge to get a nice transition.  You may want to consider adding fillets to the lower part.
