Sweeping
Sweeping
wweikert
Message 1 of 19
Sweeping
wweikert
Hey guys,
I'm trying to sweep a profile along a curved path.
Bildschirmfoto 2017-11-10 um 11.23.26.pngBildschirmfoto 2017-11-10 um 11.24.11.png
What can I do to keep the vertical lines of the profile vertical? Right now the profile is 'tilting' into the curve, but that's not what I want.
Here you can access my design: http://a360.co/2zsurZt
Thanks in advance!
Replies (18)
Message 2 of 19
Ezekiel12
Well... i dont know if I understand correctly, but it is tilting, because you created it it tilting.
I attached my file, where it is vertical to the line, because it sits on it vertical. But maybe I didnt understand something.
Message 3 of 19
wweikert
Thanks for your answer!
This tilting angle was actually on purpose.
What I want is to keep the bottom line of the profile horizontal at all the time.
This seems to be more of a geometrical Problem.
This is how far I came by creating a 'guiding rail' (German: Führungsschiene):
But I want to avoid the marked corner to be smooth. I guess this won't be possible using 2D sketches?
Message 4 of 19
Ezekiel12
You mean, like this?
Message 5 of 19
wweikert
More like that but with the marked corners smooth:
Message 6 of 19
SaeedHamza
create a plane along path using thee curve and then sketch your profile on that plane
Saeed Hamza
Message 7 of 19
wweikert
This is more or less the object I wanted to create. Any ideas how to do that in Fusion?
Bildschirmfoto 2017-11-10 um 18.55.45.pngBildschirmfoto 2017-11-10 um 18.56.42.png
Message 8 of 19
jasonhomrighaus
Just to understand you want the curved areas to be tilted onto a different plane then the long areas?
Message 9 of 19
wweikert
The curved parts actually aren't on a plane, more on a curved plane.
If you think of the inside of whole object as a tunnel, I want the floor to stay horizontal all the time.
Message 10 of 19
jasonhomrighaus
Well this is one try at it.
Message 11 of 19
wweikert
Thanks for your help, but this object has the same problems as in Post 5
The Object I created with another Software is pretty close to the one I want to create in Fusion.
Message 12 of 19
jasonhomrighaus
Here try this one, i used an offset guide rail then selected the profile and guide rail option, can make a vid if you want to flatten the base I used an offset plane and split the body, from there you could sweep on a base profile on the flat plane if you wanted.
Message 13 of 19
davebYYPCU
Your tunnel is doable, but not completely with sweep, you need the U-turn to be a Loft, due to the change of profile orientation involved at the centre of the end path curve.
you may have to realign - redesign the profiles to suit your design,
you and @jasonhomrighaus, have yellow warnings to avoid and fix.
file attached , edit my loft feature to see the settings,
might help....
Message 14 of 19
wweikert
Thank you all very much, @davebYYPCU thats exactly what I imagined!
Message 15 of 19
davebYYPCU
No problem, happy to help if I can...
Message 16 of 19
jasonhomrighaus
The yellow warnings was because I deleted bunch of extra sketches i had in there.  The Sweep feature allows you to do this without the lofting step, the difference is to have an offset guide rail.  it will leave a short gap as the sweep cannot self intersect but a quick extrude closes it all up.
Im still not sure i understood, you wanted the floor to curve like that in the corner?  if so just do what i said but dont cut off the bottom edge. this is how it looks before being cutImage 11-10-17 at 3.12 PM.jpgImage 11-10-17 at 3.11 PM.jpgImage 11-10-17 at 3.02 PM.jpgImage 11-10-17 at 3.03 PM.jpgImage 11-10-17 at 3.04 PM (1).jpgImage 11-10-17 at 3.04 PM.jpg
Message 17 of 19
wweikert
You're right @jasonhomrighaus, without cutting your solution is like I thought, thank you. I'll look deeper into that tomorrow. Thanks!
Message 18 of 19
wweikert
The final result:
I used lofts for the U-turns and sweeping for the straight paths.
Sweeping alone led to a tilt at the lower U-turn, at least with this profile and radius.
Message 19 of 19
I have been trying to figure out why sweep wasn't working (OK button always disabled) and you simple little comment solved the whole thing!
I have watched videos from Fusion, read the documentation I can find, and NOTHING says that for a simple profile/path sweep to work, that they have to be somehow connected.
In my case I used your idea of the plane along a path and did my profile sketch there with one corner coincident with the origin.
Thank you very much.
~P
