Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Sweep with Solid body
9 REPLIES 9
Message 1 of 10
2167 Views, 9 Replies
I am trying to sweep a profile to mimic the movement of a .125" ball endmill.
I can just use trace in manufacture to get the shape I want, but I would really like to be able to model the part correctly.
What is the best way to model this?
9 REPLIES 9
Message 2 of 10
jeff_strater
unfortunately, there is no great way to do this in Fusion today.  I took a look at your model, but it was not immediately obvious what body you want to sweep along what path.  You can get a close approximation using silhouette edge projection and some clever copy/split/move of the body, but that is labor-intensive, and can fail for complex bodies.
Jeff Strater
Engineering Director
Message 3 of 10
MRWakefield
Is this the kind of thing you're thinking of?
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
___________________________________________________________________________________________________________
I've created a Windows application for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
Message 4 of 10
in reply to: MRWakefield
Yes that is what I am trying to model.
How did you accomplish this?
Message 5 of 10
etfrench
I would use two coils, one with a circular section to simulate the ball end, and one with a square section to simulate the shank.
ETFrench
Message 6 of 10
etfrench
Adding the guide rail makes the sweep work.
ETFrench
Message 7 of 10
in reply to: etfrench
Got it, thanks!
Message 8 of 10
etfrench
I think @MRWakefield post would be the preferred solution 😀
p.s. To see how it was done, use the Timeline play buttons in the lower left of the Fusion 360 window.  You can also use Edit Feature to see all of the settings.
ETFrench
Message 9 of 10
MRWakefield
As @etfrench said; scroll through the timeline to see how I did it. You were close-ish, you just needed to have your profile perpendicular to the path and add a couple of revolves to model the ends of the slot/pocket. Oh yes, and use one of the paths as a guide rail for the sweep as per @etfrench's comment.
Marcus Wakefield
Message 10 of 10
jeff_strater
all of those approaches will work in this case (simple body, simple path).  Here is a more general (not 100% general, just more so...) approach to the "sweep a solid body", just FYI.
start with the tool and the path:
create a second instance of the tool at the end of the path (removed at the end), using Pattern on Path:
copy/paste body at the start and end - creates two bodies at the root (could be in another component, I was too lazy to do that):
Create a Plane Along Path at the start:
sketch on that plane, project the tool silhouette into the sketch (Project, with selection set to "Bodies"):
sweep/join that profile along that path:
then you have a body that you can use to subtract against another body, or use as a keepout volume for a mechanism, etc...
As I said, a bit of effort, but fairly accurate...
Jeff Strater
Technology Administrators
