Sweep Tool with Guide Rail Not Behaving As Expected
Fab_Things
Fab_Things
I am designing a tube with a flare in one section.  I am using the sweep tool with a guide rail.  It only renders the flare correctly on the side with the guide rail.  What do I need to do to fix this issue without having to create a guide rail on the other side of the path?  (file attached showing one side distorted)
Fab_Things
So apparently, the issue has to do with the arc of the curve for the flare.  A slight change to the curve and the problem goes away.
