Problem Selecting Face To Extrude
richardsalzman
richardsalzman
Quick question.  Sometimes I try to select a face to extrude, but there is a blue cast (see below) preventing me from selecting the shape I want to extrude (red arrow).  What is this blue cast showing and how do I get it out of the way to select the face I want to extrude?
Thanks... Richard
programming2C78B
the blue is from some other face, body, or model you have. Keep your mouse still and keep your click held down. It will show a list of every entity there and you can select the face "underneath"
Please click "Accept Solution" if what I wrote solved your issue!
etfrench
There is probably a sketch on the blue plane.  Turn the visibility off and you should be able to select the other.
ETFrench
richardsalzman
Thanks for such a quick response.  If I understand correctly, in this case it is showing what sketch is in the way.  It did not list it, but had a show/hide option to turn off the sketch.  Thanks so much for your help!
laughingcreek
what your showing in your last picture is a right mouse click.  do a long left mouse click while hovering over the spot you want to pick.
richardsalzman
Thanks guys... Got it.  That is awesome!
