Sweep fail around a Ø 4.4 mm pin, fix?
p_abt15
Message 1 of 11
p_abt15
I would like to create a custom-defined thread around a pin.
Unfortunately, the sweep is not possible and fails after a short distance.
My procedure:
  1. Extrude the pin
  2. Create a coil with a 0.01 mm pitch for the helix
  3. Create a defined trapezoidal profile
  4. Use the Sweep command
The file is attached.
What is causing this, and how can it be fixed?
Replies (10)
Message 2 of 11
bwalker145
Edit: Deleted original response, forgot I was messing with your angles.
New file attached. Not the cleanest as I didn't completely restart, but should be what you're trying to accomplish.
Message 3 of 11
p_abt15
Thanks for the solution. It seems to all go bad, when I select the wrong edge of the coil.
There are now many seperate surfaces on the tap. Do you know how to unite them?
Message 4 of 11
p_abt15
Thank you! Do you know, how to unite the surfaces on the thread? E.g. to use the press/pull tool.
Message 5 of 11
TheCADWhisperer
@p_abt15
Here is one with lead in and lead out for the thread.
But are you sure you don't want a land at the crest of the thread?
What is the function of this fastener?
Another example...
Message 6 of 11
p_abt15
The lead-in and lead-out are, of course, the nicer version of the screw, but I’m not sure how to implement them.
The custom thread is designed for 3D printing. Standard M4 threads with regular pitch and angle are very difficult to print, which is why I made my own custom shape.
I’ve already printed one, and it works really well.
Could you please share a file or example showing how you did the lead-in and lead-out? Also, the chamfer on top looks tricky to model, and I’m having trouble with it (no round edge after the sweep)
Message 7 of 11
TheCADWhisperer
@p_abt15
Before I attach my example, you didn't answer the question about the land at the crest.
Machine screws do not have pointed crests.
What does the mating hole thread look like?
Message 8 of 11
p_abt15
Right now it looks like this:
(the section view is from onshape, because I just couldn't do it in fusion)
The nut and bolt (which is the mating hole) have exactly the same shape as thread.
A better modeling would be a suiting land, as you mentioned.
I should improve this, but i don't know how.
Message 9 of 11
TheCADWhisperer
I will post example when I get a chance.
Message 10 of 11
p_abt15
I'm looking forward to it, that would be a huge help!
Message 11 of 11
TheCADWhisperer
@p_abt15
Looks like you are making progress from your other discussion thread.
Examine the Attached.
