Message 1 of 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I would like to create a custom-defined thread around a pin.
Unfortunately, the sweep is not possible and fails after a short distance.
My procedure:
Extrude the pin
Create a coil with a 0.01 mm pitch for the helix
Create a defined trapezoidal profile
Use the Sweep command
The file is attached.
What is causing this, and how can it be fixed?
