- Mute
- Permalink
- Report
We're a manufacturer of custom brushes. One method of manufacturing that we use is called "Coil Wrapped" which involves wrapping a standard metal-channel strip brush on a mandrel. This seems to me like it should be a simple part to model, but I'm getting a couple of issues.
The profile of the channel part is as seen below:
The silver represents the metal channel and the black is the fiber.
My planned workflow for this was to create a coil using the built-in tool and use a Triangular (External) section with an Inside position. The diameter of this coil would be set at the ID of the brush, in this case, 1.12". Up to this point, all good.
Where I run into trouble is when I attempt to draw this sketch above and sweep it along the edge of the triangular coil. If I don't receive a "This geometry will intersect with itself" error, the resulting geometry ends up twisting around the edge creating a blob. I'm not using any rotation or Taper Angle parameters so I don't understand why it's twisting.
It's kind of difficult to explain. The below image is the result if I try to sweep just the metal channel (silver part in 2D sketch above).
I would upload a screen cap but as it sits right now, it takes about 5 minutes for Fusion to process anything I do on this model so it would be a long boring video.
Does anyone have any ideas for how to create this model? I appreciate any help.
Max
