Message 1 of 13
- Mute
- Permalink
- Report
I would like to make a sweep using a NACA0018, with a helix curve i made using coil tool. When trying to sweep, the body is swept the way i want but it causes these segments to form in between. This might not seem as an issue but during CFD analysis its causing some error due to it. I want to remove these faces being formed, but delete command is not working.
