Sweep changes when closing edit.
jan_murberger
Message 1 of 11
jan_murberger
Screenshot 2024-08-15 at 09.33.11.jpgScreenshot 2024-08-15 at 09.33.20.jpgEDIT: Sort of solved. The sweep would not sweep top to bottom, but from below it worked. Original post: When editing this sweep it looks ok. If I close edit, it will change. What is going on?
Replies (10)
Message 2 of 11
CGBenner
@jan_murberger
Welcome to the forum.  I have moved your post to this forum since this might better be answered as a design question. Good luck.
Chris Benner
Message 3 of 11
TrippyLighting
I am going to tag @Phil.E the one formidable force here on the forum in the fight against evil bugs!
Message 4 of 11
Phil.E
It's hard to say this is a bug entirely. Sweep is giving errors with this geometry, most operations are blocked. This is partially due to extracting the coil edge from a primitive. It's not your fault that sweep is in deep water here.
I tried a few workarounds. Surface sweep, and an eventual Boundary Fill operation, seem like a promising way forward. I don't have time to complete it, nor is it obvious what the end state is going to be. But this gets you something more.
I will notify the team that works on sweep.
Phil Eichmiller
Software Engineer
Quality Assurance
Autodesk, Inc.
Message 5 of 11
JamieGilchrist
@jan_murberger ,
can you share what the finished geometry is supposed to look like?
Is this it?https://digitaltmuseum.se/021018091767/statens-jarnvagar-sj-buffert-1898-ars-modell
is it some sort of spring?
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
Message 6 of 11
JamieGilchrist
@jan_murberger
Is this what you're trying to accomplish?  If it is I'll post a little video of how I got there.
hope this helps,
Jamie Gilchrist
Message 7 of 11
jan_murberger
I edited my original post with the solution: to begin from the bottom. Then it worked. I can even overlap the sweep and it should not be possible, To me it was a bug, because when examining the problem the original sweep went into symmetric mode, sending my start point to the middle of the sweep, also causing multiple attempts where I got the alarm that it is overlapping itself.
Message 8 of 11
jan_murberger
Yes, it is this spring. I had this image and original drawings as reference. Though, everything has to be modified and compromises has to be made since it is a very small scale. Please post a video, because it is always nice to see how other users approach things.
https://digitaltmuseum.se/021017358444/buffertfjadrar-fran-alvkarleo-bruk
Message 9 of 11
jan_murberger
Thank you for the input. I am making my first real designs, so a lot is new to me.
Message 10 of 11
CGBenner
@jan_murberger Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
Message 11 of 11
JamieGilchrist
Hi @jan_murberger as promised, here is a video and my sample file.
(view in My Videos)
hope this helps,
Jamie Gilchrist
