COULD ONE OF YOU TAKE A LOOK AT THE INCLUDED FILE AND TELL ME WHAT I DID WRONG FOR THE 1 INCH NPT THREAD. IT IS TAPERING BACKWARDS. I'M PROBABLY MISSING SOMETHING SIMPLE. ANY HELP WOULD BE APPRECIATED.
Models removed.
Solved by a.laasW8M6T. Go to Solution.
Hi, I can't look at the file right now but you probably have the back distance set to model front -some value.(This causes it to taper wrong and is a bug)
If you change back to "thread faces" and apply any offset to that it should work
