Sweep cannot a simple sweep like for threading?
cekuhnen
Mentor Mentor
cekuhnen
I wanted to build a custom threading but trimming a coil with a sweep path but ran into an issue with Fusion not being able to crete a sweep like I can do in MOI or Alias.
And this is what Fusion sweep can only do:
Here is a MOI screenshot: showing you that sweep uses the flat and not freeform.
This way the square profile follows the rail path without twisting.
In Alias the trick is to have a start and end profile:
So does this mean the Fusion Sweep command cannot do such a basic sweep?
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
gautham_kattethota
Hi Claas,
Using the 'Path+Guide Rail' option for this sweep will control the twist of the profile as it is swept along the path.  You can find this option in the "Type" dropdown in the Sweep dialog.  Choose this option, select the sweep profile, path and another spiral edge in the body you already have as the Guide Rail.  That should give you the result you are looking for.
Regards
Gautham
Gautham Kattethota
Software Development
cekuhnen
Ah looks like there is some sort of an issue with the algorythm
with 0.99 it will work
Claas Kuhnen
gautham_kattethota
Probably some issue that has been fixed in internal builds.  Would you mind attaching your part to the posting?  I can look further into this.
Gautham
Gautham Kattethota
cekuhnen
@gautham_kattethota
Here it is
Claas Kuhnen
gautham_kattethota
Yes, I do see issues with sweep.  Let me look into this and get back to you.  Thanks for reporting this.
Gautham Kattethota
