SVG Import Problem
SVG Import Problem
SVG Import Problem
Hi There,
I have been breaking my head on trying to import an svg drawing to fusion 360.
attached you can find whatt i am trying to extrude, but unfortunately i can not extrude that one part.
i looked if any lines are sepperated but they are not.
And it is always on a different place.
masa.minohara
Hi @Anonymous,
Welcome to Fusion community, and thank you for posting this! The lines are green in color so I believe they are fixed. Could you try unfixing them, and then drag lines to find out where endpoints of lines don't coincide? If you can find where the issue is, try dragging a point away and put it back to the original position to see if it becomes closed sketch. If this doesn't work, would you be able to attach the file here or share a public link with me?
Masanobu Minohara
Product Support Specialist
Fusion 360 Webinars | Tips and Best Practices | Troubleshooting
