SVG Import Issues and fixing them in Fusion
wdwyer5
wdwyer5
I import svg documents from Photoshop to be extruded in Fusion. Normally this process works very well. But occasionally an error displays in Fusion at the sketch with typically one segment gone wrong. Easy to delete the offending segment but I can't seem to find how to repair the gap so I can extrude the surface. Appreciate any light that can be shone on this.
Bill Dwyer
Accepted solutions (3)
  • SVG
jhackney1972
Attach the SVG file so the Forum users can help you out.  You may have to zip it in order to attach it.
John Hackney, Retired
wdwyer5
The svg file in question attached below and the fusion native file
jhackney1972
It all depends on the Geometry.  In this particular SVG error, I could use a spline or a 3 point arc to repair it.  I am returning your model with a Fit Point Spline.
g-andresen
1. Is the asymmetry shown in the beginning of the screencast intended.
2. In this case, I could also imagine a mirroring of the profile.
günther
wdwyer5
John,
The video was super helpful- thanks for solving this mystery which has been dogging me for months!
