Message 1 of 8
SVG Import Issue- Not an accurate form and DXF import not allowing extrude
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to import a SVG or DXF file of a cycloidal gear into Fusion 360, using the Sketch, import SVG/DXF option.
I have created the file and validated the profile in several programs including Inkscape and Illustrator. The issue, however, is that when I import the SVG into the sketch, the tooth profile isn't actually accurate. It appears to be missing the curve of the tooth. Does anyone know what the issue might be?
I then tried to do the same thing with a DXF file. Again, everything imports ok, but this time I cannot extrude the profile. I have checked that there aren't any open loops.
Any help would be much appreciated. Thanks.
