Surfaces are not converting to solid
valkilakrist
Observer Observer
valkilakrist
Observer
Observer
Good members of autodesk community. I have a slight problem. For some reason the surfaces are not converting to solid when I try to stitch the part. There seems to be no faces missing from what the outside looks like.
jhackney1972
Using your Stitch command, window the complete model.  the Unstitched Edges can be identified by selecting them in turn and left clicking on the Find in Window tool at the bottom of the dialog box.
John Hackney, Retired
laughingcreek
stich only works along edges.  it doesn't work when an edge falls mid face like this one does on the cylinder shaped faces.  you will need to split the cylinders along the edge and delete the unused portion-
