Surface loft problem
jcsantilli
jcsantilli
I'm trying to create a loft but for some reason can't select the whole profile (front profile). Why is that?
Replies (11)
TrippyLighting
Because the individual lines and curves in the profile are not tangent to each other.
If you want to use the guide as a loft rail it has to touch both profiles.
jcsantilli
aaahhh !! Don't really understand why they need to be tangent, but I solved the problem.
frankvoogel
Don't get what you want to achieve. loft between two lines and the horizontal sketch as guideline? I can do that.
jcsantilli
Interesting. I don't know why I couldn't select the whole profile. The only way I was able to do it was making a bunch of individual lofts. Now I don't know if the lines and curves needs to be tangent or not. I'm going to play around between yours and mine and try to find out what's the difference. The only thing I can think is something in the "preference" but don't think so.
Thanks !
frankvoogel
  1. I don’t know. Didn’t change it. So don’t need to be tangient. I just selected one line bottom to top. After that the second one, bottom to top. The guideline as last. Succes.
jcsantilli
Yes, I just found out 10 m ago how it works. You have to uncheck chain selection and select all the lines from one side. Them the another side. Don't understand why you have to uncheck chain selection to select a chain selection 🙂
Thank you !
frankvoogel
Whahaha. If Fusion can't auto select a chain. It's not a chain anymore even it looks like a chain.
chrisplyler
In Fusion 360, a PROFILE is the shaded AREA inside a closed loop of lines. It is not a sketch element itself, but rather the recognition/identification of an area enclosed by sketch elements.
Now, a SURFACE loft does not use a profile as an input. Because, of course, it is attempting to create a zero-thickness surface. And, of course, lofting an AREA (a PROFILE) would result in a 3D solid.
So, a SURFACE loft only uses lines as inputs.
TrippyLighting
@chrisplyler a surface loft can also be created by two closed sketch profiles 😉
@jcsantilli @frankvoogel The "chain selection" refers to a tangent chain
chrisplyler
Do you mean to say that CLICKING on the profiles is a way to easily SELECT the enclosing lines? The loft itself will only use the lines of course. It won't actually loft the profiles.
jcsantilli
Understood, thank you guys
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
