Surface from Curve Network
With T-Splines for Rhino one way to create a T-Spline surface was 'skinning'. Is this way also available in Fusion 360 and, if yes, are their any tutorials showing how it's done? Thanks.
jeff_strater
Hi @Anonymous,
Unfortunately, Fusion does not have this TSpline command today.  I suggest that you put this as a suggestion on the Fusion Idea Station.  I did a quick search there, and did not see this suggested.
Jeff
Jeff Strater
Engineering Director
I guess if it's not there it probably wasn't ment to be there in the first place. But I suggested it. Thank you.
