How do you create a surface from compound curves?
I'm trying to model the heel of a stiletto type shoe. Initially it seems simple, but the ground plane and top curves are not in parallel planes, so it seems Revolve, then Draft are not options. I've spent most of the day trying various settings for Sweep, Loft, and Patch tools. This seems like something that could be done in a few minutes in Rhino.
Can Fusion360 model a surface from compound (two) curves in non-pafallel planes, or am I missing something?
I've read these related threads and/or watched the following tutorials (plus many others):
https://forums.autodesk.com/t5/design-validate-document/sweep-two-rail/td-p/4349982
https://knowledge.autodesk.com/community/screencast/196c023e-9971-4ea2-bcb0-6ba4db07a2cd
Thanks!
