revolve angle
revolve angle
Message 1 of 24
revolve angle
Here is a picture of what i am trying to do. I have use the Revolve to create a cut away and i am trying to recreate an angle up. Not sure if the photo load up, I am happy with the cut away, i just want the key way or cut away to go up on an angle towards the big section, if that make sense.
Thank you if some one may be able to help.
Regards Paul
Replies (23)
Message 2 of 24
jeff_strater
Hi @Anonymous,
It looks like your picture did not get attached.  Can you try again?  Also, if you are willing to share the model, that would be an even quicker way to get your question answered.
Jeff
Jeff Strater
Engineering Director
Message 3 of 24
Sure happy to share, how. I will try and re load again. Thank you
Message 4 of 24
please let me know if the photo up loaded, thank you.
Message 5 of 24
jeff_strater
Thanks for the image.  I'm not entirely sure I understand your request, but here is a first attempt:
If this isn't what you are trying to achieve, I apologize, perhaps just sketching on the image to show the result of what you are trying to do would help.
Jeff
Jeff Strater
Message 6 of 24
here what i am trying to do, i up load the second one, thank you
Message 7 of 24
i have sketch what i been trying to do, thank you for your help
Message 8 of 24
TheCADWhisperer
Sweep a line along curve to get surface body.
Thicken the surface body to remove the material.
Attach your *.f3d file here if you can't figure it out.
Message 9 of 24
jeff_strater
Ah...  much clearer now.  I understand what you mean by "angle" now.  This probably needs a sweep of some kind.  Here is one way to do this.  I'm not sure it's the best, but it should maybe give you some idea how to approach the problem.  In this screencast, I ended up with a path that does not intersect the profile, which, as the warning indicates, is not ideal.   It does work, but is not a best practice.  But, you get the idea, hopefully.
Jeff
Jeff Strater
Message 10 of 24
TheCADWhisperer
I would caution that sweeping a rectangle does not result in the same geometry as sweeping a cylinder (end mill cut) along the curve.
You can check this by placing a pin (cylinder) in the slot and checking for interference.
A thickened swept surface (end mill path) will return the correct geometry.
Message 11 of 24
jeff_strater
Very good point. You are correct, the thickened surface results in better geometry. I can do a screencast of this later, if it's not obvious
Jeff
Jeff Strater
Message 12 of 24
jeff_strater
Here is a screencast doing it the way that @TheCADWhisperer suggests.  This is a great technique, and I'll keep it in my bag of tricks for future use!
Jeff
Jeff Strater
Message 13 of 24
Thank you guys for your help, i am only new to cad or anything like this, like 2 months, but i am loving it. I love if you could do it slower, so i could catch on. Sorry to be a pain. i get most of it. Just the start of it i struggle with, I know i am asking a lot, but a great thing i we keep under my belt. I know you guys have work to do, So thank you again.
Message 14 of 24
It is the off set plane on angle i am trying to figure out, Thank you
Message 15 of 24
jeff_strater
I didn't use an angled plane for this.  I just drew a line on an offset plane, and used Project Curve to Surface to get it into a sketch.  Although an angled plane would probably be a better idea, now that you mention it.  Here is how I had to do this:
Jeff
Jeff Strater
Message 16 of 24
Thank you, for re-doing it slowly, this look like what i want. I give it a go and get back to you.
Thank you for your time.
Message 17 of 24
Hi Jeff, Thank you for taking the time to show me, I was able to do it on one side, but i need to repeat the process 180 side, for some reason it not letting me, I will send a screen shot through.
I get what you are doing now, off set plane, sketching a line on the off set plane and then using the tool to transfer in onto the Org plain to follow the curve of the cylinder, So here a photo.
Message 18 of 24
For some reason You can see that the Angle circus is in complete, so i can not Project on to the cylinder, I have try every thing for hours. I am missing something.
Thank you again
Paul
Message 19 of 24
I need 2 keys way on the cylinder opposite each other,
Message 20 of 24
Ok i think i can see what the problem is, Where i cut away the first key way it stopping the completion of the second Line to complete, so how do i get around this.
