Why Sweep 2 Rail is so important
cekuhnen
Mentor Mentor
cekuhnen
Here is a rounded edge from an iPhone 6 model done in Fusion checked in Alias
The combs are crappy - but so are those in Alias (left image)
To build a full model I need
two side surfaces / profiles which give me also the rails I could sweep a profile along.
The rials then of course also need G1 G2 options.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
innovatenate
Autodesk Support
Autodesk Support
I'll add your IdeaStation request to this topic, in case there are others in agreement.
http://forums.autodesk.com/t5/fusion-360-ideastation-request-a/sweep-2-rails/idi-p/5466538
Nathan Chandler
Principal Specialist
cekuhnen
sure go ahead - many voted on it already
I think to get Fusion out of the engineer software corner surfacing tools also should behave like in typical surfacing apps.
You really don't want to expect designers to know both - which might not be bad to do anyway but then Fusion is not the easy tool anymore it should be as far as I know.
Claas Kuhnen
