Surface artefact on a mirrored freeform model
Right side with artefactRight side with artefactRight side with artefactRight side with artefactLeft side without artefactLeft side without artefact
I do not understand how it is possible that there is an artefact on one side of a mirrored freeform surface but not on the other. Does anyone know whats going on there?
Could this effect the qualitiy of later renderings?
TrippyLighting
This is likely a tessellation artifact. If you finish the T-Spline, is that still visible ?
if so, right-click on the body and select Display detail control. Change it from adaptive to fixed/high. If that does not correct the issue, then post the modeL 😉
