Suppress operation in the timeline with a parameter
Christoph_360
Christoph_360
Hello everyone
Is it possible to suppress or reactivate an operation in the timeline with the help of a parameter?
Does anyone have any ideas?
Mfg
Christoph
TrippyLighting
No, that is not possible. I am not entirely sure what you are trying to accomplish, but my best guess is that you are looking for a feature set that is called "Configurations" in other CAD software packages.
This is currently in beta test and might be released late(er) this year.
Christoph_360
Hello
Thank you for this information
I want to create a variant model that controls multiple variants with one parameter.
I have now managed to do this in a roundabout way, but if I could activate and deactivate operations in the timeline, the task would be easy to solve.
Mfg
Christoph
Christoph_360
Hallo
So far, I have been able to control such tasks with the help of a table
                                                           Hole                d1
Block 100 long without hole         0                      100
Block 150 long without hole         0                      150
Block 100 long with hole               1                      100
Block 150 long with hole               1                      150
Using the Hole parameter, I was able to enable or disable the operation.
If I inserted the component into an assembly or derived the component, I was able to select the variant.
If they mean something similar by "Configurations", then that would be exactly what I need.
Thank you for your efforts.
Mfg
Christoph
Christoph_360
Hello
Thank you very much, I searched for modifications on Youtube at Inventor and found videos with Inventor iLogic.
This seems to be exactly what I'm looking for and is also listed in Fusion's roadmap.
Mfg
Christoph
